ADT70 platinum thermal resistance temperature measurement circuit
Source: InternetPublisher:sigma Keywords: ADT platinum thermal resistance temperature measurement circuit BSP Updated: 2020/12/12
The basic electrical parameters of AD170 are as follows: temperature coefficient 25ppm/"C, temperature measurement accuracy ±1℃, maximum temperature measurement range is -200
~+1000qC, working power supply +5v or t5v, working temperature range is -40-+125℃.
( 1) PRTD platinum thermal resistance temperature measurement circuit. Since ADT70 integrates voltage source, current source and amplifier circuit,
the peripheral circuit is very simple when using it for temperature measurement. As shown in Figure 1-47, ADT 70 platinum thermal resistance Resistance temperature measurement circuit .
PRTD is a 4-wire (one end of the 2 wires is connected to +INIA, /OUTB, and the other end of the 2 wires are connected to ground and the ⑩ pin of the operational
amplifier ) temperature measurement platinum resistor, the ruler is the reference resistor, and the matching current Source output current, OUTA and /OUTB are added to the reference
resistor, instrument amplifier - UNIA and platinum resistor, instrument amplifier + INIA respectively. The temperature measurement signal output by the platinum resistor
is amplified by the operational amplifier and instrument amplifier at the same time and then output from pin ⑩. The gain of the instrument amplifier
is determined by the adjustable external resistor Rc
G =49. 9kfl/Rc
- An article explains the working principle of the Wheatstone bridge
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- This article will tell you the hard requirements of operational amplifiers
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- Transfer characteristics of BJT, how to apply Shockley equation?
- Datasheet/Pinout/Technical Specifications of LMC555
- Tutorial on building a NOT gate using BJT transistors
- What types of force sensors are there?
- Introduction of TDA4863J/4863AJ TV field scanning IC
- LED Bicycle Lights
- Analysis of rectifier circuit types and principles
- Egg heating control circuit
- Farmland irrigation automatic control circuit b
- Diode balanced amplitude modulation circuit
- Schiller oscillator circuit
- Differential Amplifier Circuit
- Second-order active band-stop filter circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Various signal generator circuits
- ADT70 platinum thermal resistance temperature measurement circuit
