AD524J type thermocouple cold junction compensation temperature measurement circuit
Source: InternetPublisher:清宁时光 Keywords: Thermocouple temperature measurement circuit AD BSP Updated: 2021/04/16
AD524J type thermocouple cold junction compensation temperature measurement circuit is shown in Figure 1-20. This circuit consists of J-type thermocouple detection,
reference voltage source AD580, integrated temperature sensor AD590 and precision instrument amplifier AD524. AD590 compensates the cold
junction. When the temperature of the cold junction changes, AD590 outputs a current at lVA/K. This current The voltage formed at pin ② of AD524
is superimposed with vI to change the output of the amplifier. The AD580 provides a 2.SV reference voltage.
AD 524 is a high-speed (output conversion rate is 5V/ms) operational amplifier with low drift (voltage drift 0.5mV, maximum temperature drift 25 mV/oC) and good linearity (when the gain is l,
the linearity is 0,003%) .
- Does lithium iron phosphate battery need a protection board? The correct way to charge lithium iron phosphate battery
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- An article explains the working principle of the Wheatstone bridge
- Causes of PCB deformation How to prevent circuit board bending and warping
- Why use PWM? What are its advantages?
- Important things to know about PCB routing and how to design the right routing for your PCB
- What is a Demultiplexer
- Touch circuit design and analysis
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- electromagnetic field sensor
- AD7715 internal functional block diagram and pin function diagram
- Precision automatic temperature control circuit
- AD594 to 597 basic application circuit b
- AD596-597 functional diagram
- AD524J type thermocouple cold junction compensation temperature measurement circuit
- AD574 and PC bus interface circuit
- AD694 forms a 4 to 20mA transmitter circuit
- AD208 circuit functional block diagram
- Weak signal detection circuit composed of AD650
