Basic application circuit of AD590 b
Source: InternetPublisher:抄写员 Keywords: Application circuit AD BSP temperature detection Updated: 2020/08/28
Shown is a basic application circuit for the AD590.
Since the AD590 is a current output, a series resistor can convert the output current into voltage. Figure 1-31 (a) is the most
basic application circuit . The output current of AD590 is in Zhan. , the voltage formed on RP is used as the output vo, and RP is used for output trimming.
For example, when Ri+RP=1. OK, at 25℃, the output vo=298. 15 bcA×lk0,=298. 15mV. Figure 1-31
(b) and (c) show the series and parallel applications of AD590 respectively. More than three of them can be connected in series or in parallel at the same time. AD590 series application can be used for multi-point temperature detection
in a small space ; Figure 1-31 (b) The output voltage
is based on the position of the AD590 with the lowest temperature, Figure 1-31 (c) The output voltage is the average of several AD590s, It can improve
the accuracy of multi-point temperature detection .
AD590 is very easy to interface with CMOS digital circuits. It can be connected to gate circuits, analog electronic switches, etc.
Figure 1-31 (d) is a circuit using a NOT gate as an electronic switch for multi-channel temperature detection . The output voltage is affected by Cl,
C2, C3 terminal control. For example, when cl -0, C2=1, C3 =1, the output is AD 590 -1.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- How to identify common mode interference? Methods to eliminate common mode interference
- How to calculate the value of capacitors in parallel?
- DIY a decorative lamp
- Analysis of three simple electronic dice circuits
- How does RCCB work?
- Ceramic filter structure/working principle/characteristics/application
- Simple LED advertising light circuit
- LED Bicycle Lights
- Motor overcurrent protection circuit
- AD524J type thermocouple cold junction compensation temperature measurement circuit
- Introduction to the high-precision ±5V reference source AD586
- Internal block diagram of ADP3000 integrated circuit
- Revolution or pitch counting circuit
- Battery charge controller ADP3810/3811 circuit
- Principle circuit diagram of automatic converter for power outage emergency lights
- AD693 type 4 to 20mA sensor transmitter circuit
- AD586 superposition circuit diagram
- AD7660 negative voltage and positive voltage doubler output circuit diagram
