Low supply voltage diode temperature measurement circuit
Source: InternetPublisher:sigma Keywords: Diode power supply voltage temperature measurement circuit BSP Updated: 2020/05/14
In battery-powered circuits, low voltage and low power consumption are required. A low power supply voltage diode temperature measurement circuit can meet
the requirements, as shown in Figure 1-27. The temperature measurement range of this circuit is O-125℃, and the accuracy is ±0.5℃.
Ri, R2, and VD are temperature detection components, IC1 is a 1.2V precision reference voltage source, and RP1 adjusts the potential of pin ③ to
calibrate the output temperature. For example, at 25°C, adjust RP] to
make the output voltage 250mV. Every time the temperature on diode
VD
changes by 1°C, the forward voltage drop will decrease by about 2mV. This change is reflected
in the voltage on the diode VD, and the output voltage change after amplification by IC2 is
10mV/oC. LT1101 is set through internal resistors. Let the gain
be lo.
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- An article explains the working principle of the Wheatstone bridge
- Analysis of the basic principle of measuring resistance by bridge method
- How to read resistor color codes? Resistor color codes illustrated
- Analysis of the working principle of CMOS/CCD image sensor
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- What is a D flip-flop and how does it work?
- DIY a decorative lamp
- Experiment and production of NE555 time base integrated circuit
- High-efficiency speaker circuit for rural stage
- Crop anti-frost circuit
- Fish farming thermostatic control circuit
- Agricultural spraying and insecticide control circuit
- ring amplitude modulation circuit
- Audio function generator composed of ICL8038
- Parallel crystal oscillator
- OTL low frequency power amplifier circuit
- Voltage series negative feedback amplifier circuit
- Sawtooth wave generator circuit (1)
