AMP-04 0 to 400℃ temperature measurement circuit
Source: InternetPublisher:super_star Keywords: Temperature measurement circuit BSP Updated: 2020/05/24
The AMP-04 is a high-resolution operational amplifier powered by a single power supply and with single resistor gain adjustment. The input voltage drift is less than 150 pLV, the current drift is less
than 5nA, the temperature drift is 8 pA/aC, and the gain nonlinearity is 0.005%. AMP-04
0. 400qC temperature measurement circuit is shown in Figure 1-13. The temperature measurement range of this circuit is 0-4000C, and the measurement accuracy is ±0.5℃.
Ri - R3, RPi, and RTD form a bridge
temperature detection circuit, RP, to adjust the bridge balance;
IC2 and IC3 are constant current and constant voltage sources, 1C3 outputs
a 2.500V precision reference voltage, which is
adjusted by Rs, R6, and RP2 to make IC2 . (+) terminal potential is
0. 202V, IC2. A constant current is output and added to
the bridge. The output of the temperature measurement bridge is directly sent to
Icl for amplification. Pin ① is connected to an external resistor to adjust the gain
, and RP4 is used to fine-tune the gain. When the temperature changes from 0 to
4000C, the output voltage is O—4. OV .
When debugging, first use a 100. 00Q resistor
(equivalent to 0℃) instead of RTD, adjust
RPi so that the output voltage is 0.oOv; then
use 247. 04 (equivalent to 400C) and 175. 84n resistors (equivalent to (at 200C) instead of RTD, adjust RP4 and
RP3 respectively so that the output voltages are 4.00 and 2.0 OV respectively .
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- In-depth analysis of energy losses in oscillation frequencies
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- How to calculate the value of capacitors in parallel?
- Simple Wired Spy Bug Circuit Built Based on IC741
- Working principle/advantages/disadvantages/size of optical fiber
- Why use PWM? What are its advantages?
- Simple LED advertising light circuit
- An example of proportional integral circuit diagram
- Circuit diagram of a differential amplifier circuit
- Electronic thermometer circuit
- stuttering correction circuit
- Inpatient pager circuit
- Chicken supplementary light to increase egg production rate circuit
- Diode Balanced Mixer Circuit
- Frequency modulator composed of NE566
- Schiller oscillator circuit
- Double gate field effect transistor high frequency amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Motorcycle flash light circuit
