INA114RTD precision temperature measurement circuit
Source: InternetPublisher:ghaytweyhtoo Keywords: Temperature measurement circuit BSP Updated: 2020/07/13
INA114 has high sensitivity, high input impedance (10lOn), high common mode rejection ratio (not less than 115 dB), low drift
(maximum voltage drift 50Lr,V, maximum temperature drift 0.25 VV/aC), adjustable gain (L— 10000) instrument amplifier. The working
power supply range is ±2.25~±18V, and the input can withstand ±40V overvoltage. INA114 is very suitable for sensor circuits. The precision temperature measurement circuit
formed by it and the thermal resistor RTD is shown in Figure 1-10. REF200 is a dual lOO pL.A precision current source. The value of Rs should be equal to the resistance value
of the thermal resistor RTD at ooc . In this way
, at ooc, the (+) and (1) inputs of INA 114 are at the same potential at oac. The output is 0. In the temperature measurement state, as
the temperature changes, the resistance of the RTD changes accordingly, and
the potential of the IIVA114(+) terminal also changes, and after amplification,
a signal voltage of a certain amplitude is output. Rc is the gain
adjustable resistor, the gain G=1 +50kfl/Rc, and the adjustment range is
1-10000. The output voltage is vo=C (v+.-v-).
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- How to calculate the value of capacitors in parallel?
- Simple Wired Spy Bug Circuit Built Based on IC741
- Diode-based clipping circuit
- Basic characteristics/working principles and application circuits of tunnel diodes
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- Make a flameless electronic candle using simple electronics and LEDs
- Star finder battery indicator circuit
- Experiment and production of NE555 time base integrated circuit
- Homemade air conditioner outdoor unit shutdown indicator
- Chicken supplementary light to increase egg production rate circuit
- Straw returning to field crusher circuit
- Greenhouse temperature control circuit
- Junction field effect transistor mixer circuit
- Double detuned loop frequency discriminator circuit
- ring amplitude modulation circuit
- Audio function generator composed of ICL8038
- Parallel crystal oscillator
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Sine wave signal generator circuit
