LED backlight driver module design circuit
Source: InternetPublisher:抄写员 Keywords: LED backlight driver module module design Updated: 2021/05/29
![LED backlight driver module design circuit](http://www.eeworld.com.cn/circuit/upload/244bf1ac15a0fec9755233e385c82568/790a3ffb3152cbbaf49297fb07b9cdc2.jpg)
Circuit analysis: The requirement of the backlight driver is that the brightness of the backlight LED remains unchanged under any conditions, that is, a constant current source circuit needs to be constructed. The backlight drive circuit shown in the figure is the simplest constant current source circuit. When the circuit is working, the voltage across resistor R9 is equal to VLL1 plus the BE conduction voltage, which is a fixed voltage of about 1.7V. The current flowing through R9 is also fixed. The current is approximately equal to the emitter current and collector current of Q2, so the current flowing through the backlight diode D1 is also a constant current, realizing the constant current drive of the backlight LED. The driving current of the backlight LED is about 10mA, and the value of R9 is 150Ω.
- 220V Remote Load Monitor
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Energy-saving motorcycle rectifier regulator
- Basic circuit description of adjustable voltage regulator LM317
- Driving circuit that controls LED brightness using PWM signal
- Simple and practical LED lamp driving circuit
- Low cost and high performance LED constant current power supply
- Integrated regulated power supply with continuously adjustable output voltage
- Car power 1.5V-12V six-speed converter
- Car Audio Power Supply
- Power circuit b composed of intelligent thyristor modules
- Portable device charging power circuit design
- Typical Reference Voltage and Power Supply Circuits
- Power circuit of LBO-522 dual trace oscilloscope
- 4-phase CPU power circuit using HIP6301 and HIP6602 chips
- audio power circuit
- Additional power circuit design for USB devices
- Wide input 350mA LED driver circuit based on NCL30000
- Practical neon light power circuit
- Inverter power circuit made with BJ50A
