Electronic power saving mousetrap circuit
Source: InternetPublisher:Lemontree Keywords: save electricity power supply Updated: 2020/10/02
The energy-saving electronic mousetrap introduced in this example usually consumes very little. It only works when mice enter the control area to look for food, and then delays for 30 seconds and then enters
the waiting state. It is very suitable for hunting mice in the wild.
(1) Working Principle Figure 23-11 is the circuit diagram of the
electricity- saving electronic mousetrap. VT1 ~
VT4 and related components form a control circuit,
whose function is to report whether a mouse enters the control
area, and to control the power supply
of the alarm and high-voltage generating circuit . IC, VT5, etc. form an alarm
circuit. When a mouse enters the control area,
the IC sends out an alarm signal, and VT5 drives the speaker
BL to sound.
The transmitter is composed of VT6 and peripheral components , with an operating frequency of 88 to
108 MHz and a transmitting distance of more than 1 km
to facilitate long-distance monitoring. VT7, T,
VD2, etc. form a high-voltage generating circuit, which outputs
hundreds to thousands of volts of high voltage to kill
mice entering the control area. When the manual switch
SA is closed, the power supply supplies power to the control circuit
. At this time, VTI-VT4 are all cut off, the
relay K is not energized, the alarm and the high-voltage circuit do not work. When a mouse enters the trigger net, it is equivalent to adding a resistor between the A and B electrodes.
VT1~VT4- are all conductive, relay K is closed, its contact K is closed, and the power supply of the alarm and high-voltage generating circuit is turned on. At the same time, the power supply
charges cz through VT1 and VT2, so that when the mouse leaves the trigger net, the relay delays for about 30 seconds and then turns off. This prevents VT7 from
being damaged due to long-term work, and also reduces the useless power consumption of the power supply . The alarm signal sent by the IC passes through the speaker BL carbon sound. The other modulates
a high-frequency oscillator composed of VT6 and transmits it outward. At the same time, the light-emitting diodes LED1 and LED2 emit light. At this time, the rat was frightened and
escaped from the trigger net t into the high-voltage electric current and was killed. When the remote monitoring personnel receive the alarm signal using FM radio, they can go to the scene and
remove the dead rats promptly.
- Detailed explanation of the working principle of the parking light circuit
- How to use MFRC522 to create an RFID card reader security system
- One control two constant pressure water supply frequency conversion speed control circuit b
- morning bird
- 220V AC mains directly drives small relay circuit_3
- SCR control buzzer circuit
- Blind electronic cane circuit
- Box type electronic mousetrap circuit
- Toy police car circuit
- Chinese learning machine disk drive interface card circuit diagram circuit
- How to Select TVS Diodes in Hot Swap Applications
- Provides USB Type-C® port chip solutions for lithium battery-powered devices
- Minimize noise and ripple using low-noise buck converters
- How should the inductor of the switching power supply be placed correctly in PCB design?
- How to ensure that the power supply works efficiently for a long time?
- What are the precautions for using current monitors?
- Set timing circuit when power is on
- Automatic reset timer circuit
- AD596-597 functional diagram
- Floating input circuit (5V power supply)
