Signal input circuitb
Source: InternetPublisher:桂花蒸 Keywords: Input circuit BSP microcontroller Updated: 2021/01/30
Signal input circuit: The signal input circuit includes two parts: the remote control signal
input circuit and the key signal input circuit
, as
shown in the figure. The remote control input signal is processed by the remote control receiving head (X4) and the signal processing circuit composed of R9, wind and
C7. The processed signal is directly input to pin 27 of the microcontroller
in a series of continuous codes. The microcontroller
determines the instructions input by the user based on the decoding program and outputs the corresponding control signal to the actuator.
At the same time, there are two manual buttons Sl and S2 on the indoor unit. When the remote control fails or needs maintenance, you can use these two buttons to input instructions
to control and check the operation of the air conditioner. These two keys connect the zero level of the microcontroller
through the on-off mode of the mechanical switch, so that the
command signal of the @ pin or @ pin forms a path, which can improve the ability of human-computer dialogue.
The AUTO key is an automatic working switch, used to control the start and stop of indoor and outdoor units. Press it once and the air conditioner
will operate in automatic mode; press it again and it will stop running. The temperature setting standard is 27℃, and there is no timing control function. The TEST key is a debugging key, which can
detect the entire working process of the system based on the pre-programmed software program of the microcomputer.
- How to Build a Simple FM Radio Receiver on a Breadboard
- Circuit principle and production of six-tube radio
- A cheap and easy-to-make infrared TV signal repeater
- Convenient and practical electric guitar wireless transmitter
- RX3408 FM/FSK 500~20 MHz Receiver
- MICRFl04 ASK 470~300 MHz Transmitter
- XEl209 70~30 kHz Ultra-Low Power CMOS Transceiver
- rfPICl2C509AG/509AF ASK/FSK 480~310 MHz with 8-bit microcontroller transmitter
- DKIOOOT OOK 315 MHz Transmitter Module
- T5761/T5760 ASK/FSK 870~868 MHz/928~902 MHz Receiver
- electromagnetic field sensor
- Bone hyperplasia treatment circuit
- Inpatient pager circuit
- Straw returning to field crusher circuit
- DC ammeter
- collector amplitude modulation circuit
- Audio function generator composed of ICL8038
- Broadband high frequency power amplifier circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Sawtooth wave generator circuit (2)
