Parallel DC regulated power supply circuit
Source: InternetPublisher:抄写员 Keywords: DC regulated power supply regulated power supply circuit parallel type BSP Updated: 2020/02/01
Shown is a parallel DC regulated power supply circuit. The 220V power supply is stepped down by a transformer, followed by full-wave bridge rectification, capacitor filtering,
voltage stabilization and tube stabilization, and the output DC voltage is supplied to the load. The output current voltage is equal
to 0.9 times the secondary side voltage of the power transformer. Due to its simple circuit, this power
supply is used in less demanding situations. ,
the mains power U1 (Ul -220rD is stepped down by the transformer to obtain the AC voltage
U2 (UZ "UI N2 /N,). The AC voltage U2 is passed through the single-phase bridge rectifier circuit
to obtain the DC voltage U (Uz≈l.2?L2 ), in order to prevent sudden voltage
changes in the circuit, the capacitor and the load resistor must be
connected in parallel through the filter circuit to absorb the pulsating current and keep the output voltage stable. The output voltage after going through the
rectifier filter circuit and The DC voltage we seek is still quite far away. In order to obtain a more stable DC power supply,
we need to stabilize the voltage through the voltage stabilizing circuit after the rectifier and filter circuit, thus obtaining the DC voltage we seek.
- Analysis of the working principle of switching regulator
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Schematic diagram of car cigarette lighter to USB power port
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Dual forward converter schematic diagram
- Power supply circuit that can reduce LM317 ripple
- Homemade low-power UPS
- MIC4680 constant current charger
- Homemade Electric Bike Fast Charger
- Analysis of rectifier circuit types and principles
- Self-defense anti-riot circuit
- Soil water shortage prompt circuit
- Varactor Diode Frequency Modulator
- base amplitude modulation circuit
- collector amplitude modulation circuit
- Double gate field effect transistor high frequency amplifier circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Second-order active band-stop filter circuit
- High and low frequency signal generator circuit
