Transistor controlled rectifier circuit b
Source: InternetPublisher:天天都吃好吃的 Keywords: transistor rectifier circuit controlled rectification thyristor Updated: 2020/07/13
Without affecting the accuracy of engineering calculations, when analyzing the rectifier circuit below, both the thyristor and the rectifier diode are regarded as ideal
components , that is, the forward voltage drop during turn-on and the leakage current during turn-off are ignored. ·And the turn-on and turn-off are instantaneous.
The thyristor controlled rectifier circuit is shown in Figure 12-8a-d. Their working principles are
similar to ordinary diode non-controllable rectification circuits
. The difference is that the thyristor must have a forward voltage between the anode and the cathode, and a certain trigger pulse between the gate and the cathode. signal
to conduct the work. Each thyristor requires a trigger circuit. The load is resistive and inductive.
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Build a simple buck-boost regulator and test it on a breadboard
- Schematic diagram of car cigarette lighter to USB power port
- Practical and convenient fax machine power supply control circuit
- Basic connection circuit of signal and power supply composed of ISOll3
- Transformerless AC-DC constant current LED driver circuit
- Boost drive circuit composed of RT8450
- Integrated regulated power supply with continuously adjustable output voltage
- USB power socket using the car battery
- Homemade Electric Bike Fast Charger
- Transistor controlled rectifier circuit c
- Transistor controlled rectifier circuit b
- Step-adjustable integrated regulated power supply
- Even-numbered voltage doubler full-wave rectifier circuit d
- Three-function lantern chain circuit using SZ-9201 Part 2
- Rectifier circuit
- Single-phase bridge thyristor rectifier circuit
- AC input automatic switching and rectification circuit diagram
- voltage doubler rectifier circuit
- Crystal diode single-phase bridge resistive load rectifier circuit
