Microphone preamplifier with phantom power using INA103
Source: InternetPublisher:他们逼我做卧底 Keywords: Amplifier Updated: 2024/07/31
As shown in the figure, this is a microphone preamplifier with phantom power. When the "phantom power" switch is connected to 48V, a 48V DC voltage is provided to the microphone; when it is connected to 47kΩ, a 0V DC voltage is provided to the microphone. Two 20dB attenuation linkage switches control whether the input signal is attenuated by 20dB (i.e., whether the voltage is divided). The 1kΩ "gain adjustment" potentiometer can adjust the amplifier gain to change the output signal size. The OPA627 forms an output offset voltage control loop to control the offset voltage of the output stage A3.
- Gain Cloning Power Amplifier LM3886
- TDA2002 8W Car Radio Power Amplifier
- TDA1011 6.5W Power Amplifier
- USB Audio Digital-to-Analog Converter
- DS1802 Stereo Digital Volume Controller
- Class A push-pull tube power amplifier
- 30W MOSFET audio amplifier
- TDA1551 audio amplifier circuit diagram
- Make a pocket amplifier with 8550 and 8050
- Delayed soft start circuit of tube amplifier
- Precision current detection amplifier design based on lithium battery detection
- Detection circuit diagram of AC side voltage Us based on SG3525
- Valuables detection circuit design
- Inductively Coupled Voltage Amplifier Circuit
- Operational amplifier negative feedback circuit diagram
- Single Supply Op Amp Applications
- non-diode rectifier
- Oscilloscope converter provides four channel display
- Video driver schematic
- OTL low frequency power amplifier circuit
京公网安备 11010802033920号
