DS1802 Stereo Digital Volume Controller
Source: InternetPublisher:rK5jdn Keywords: DS1802 Volume Control Updated: 2026/01/13
The DS1802 is a stereo digital volume control integrated circuit. It consists of two 65-bit, 45kΩ digital potentiometers with logarithmic resistance, increasing by 1dB in each step. It can be operated automatically via a three-wire serial interface under software control, where the slider setting is written with an 8-bit word, or via simple contact closure under push-button control. The component can be used in 3V or 5V environments and operates anywhere within the industrial temperature range of -40°C to +85°C. The DS1802 supports daisy-chaining with other devices under single-processor control.
In addition, the DS1802 has four contact points for button control. When combined with mode control, this allows for eight different button control functions. Secondly, the DS1802's potentiometers can be controlled individually or in stereo mode control, where the sliders of two potentiometers are positioned together from a single control input.
The DS1802 provides high-performance audio volume and tone control in most applications that use mechanical potentiometers, including CD players, guitar amplifiers, and sound cards. The digital potentiometer consumes very little power while providing digital accuracy and reliability under flexible, automated processor control.
The DS1802 chip costs only a few dollars and requires no CPU! Its unique feature is the use of simple up/down/mute buttons. It's very easy for DIY enthusiasts to handle. Furthermore, the chip is manufactured in DIP format, making it convenient for those of us who prefer point-to-point wiring.
I think if you need 5.1 channels, you can combine three of these chips together and connect the buttons in a purely linear or parallel manner. As long as they all power on at the same "cold" boot time, they will remain synchronized.
Key features
Two digitally controlled 65-bit potentiometers
Ultra-low power consumption
Software and hardware controlled mute
Digital or mechanical button slider control
Potentiometers can be linked for stereo control.
Logarithmic resistance characteristic (1dB per step)
Zero-crossing detection to eliminate noise
Serial port communication
It can be daisy-chained for single-processor, multi-device designs.
Operating temperature range: -40°C to +85°C
Operating voltage range: 3V or 5V
Available resistor: 45kΩ
- USB powered PC headphone amplifier
- High-fidelity headphone amplifier
- LM3886 power amplifier with custom chassis
- 200W MOSFET power amplifier
- USB audio digital-to-analog converter using PCM2704
- Class A push-pull tube power amplifier
- Miniature voice recording and playback circuit
- TDA7264 audio power amplifier circuit
- Using LM3886 to make a 50W high quality power amplifier circuit
- Simple and easy to make TDA2003 power amplifier circuit
- LA4461N audio IC circuit
- TDA2030 audio power amplifier circuit diagram
- Voice controlled bird circuit
- Transistor Audio Mixer Circuit Diagram
- 2-tube FM microphone with 3V power supply
- Simulating bird call circuit schematic diagram
- Several good field effect transistor power amplifier circuit diagrams
- Squelch Tuned Audio Switching/Mixing Circuit Diagram
- transistor audio mixer
- High quality melody circuit
京公网安备 11010802033920号
