Ohmmeter circuit
Source: InternetPublisher:小胖友 Keywords: BSP resistance measurement VR Updated: 2021/02/09
A multi-range ohmmeter. In this circuit, the operational amplifier is powered by a single power supply . The resistor R to be measured is connected across the feedback loop of the operational
amplifier . The reference voltage VR EF is added to the non-inverting terminal to obtain
J=VwtR/R1 (R,.+R2)
~1,
it can be seen that the current j is proportional to the resistance being measured. Moreover, the meter head has a linear scale, and
changing the resistance Ri can change the range of the ohmmeter.
This ohmmeter does not require a zeroing mechanism because it measures short circuit (i.e. wind =
0). The circuit becomes a voltage follower. Vo— VR EF, so the meter current is zero, realizing
automatic zero adjustment.
The voltage regulator tube plays the role of protecting the meter. If there is vs, when R exceeds the range
, especially when R - oo, that is, when the measurement end is open circuit, the output voltage of the operational amplifier
will be close to the power supply voltage. Overload the header. To this end, set vs to implement output clamping to
prevent overloading of the meter.
- Multimeter with small capacitor test circuit
- Balcony intelligent invisible anti-theft net
- New function added to MF-47D multimeter - infrared remote control detection
- Fire detector made with photodiode
- Homemade LED digital display photovoltaic meter
- A low-cost inductance meter consisting of a single IC
- Low resistance connection tester circuit diagram sharing
- Directly coupled push-pull power amplifier circuit
- Three-phase three-wire active energy meter connected to three ammeters
- Temperature voltage conversion circuit
- strain sensor
- Analysis of rectifier circuit types and principles
- Inpatient pager circuit
- Rice mill circuit
- Particle clogging alarm circuit of wheat seeder
- Integrated synchronous detector composed of analog multiplier MC1596
- Wien bridge oscillator circuit
- Double gate field effect transistor high frequency amplifier circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Guest arrival signal recognition circuit
