Common-mode voltage breakdown of op amp input stage and its protection measures
Source: InternetPublisher:方世玉223 Keywords: Op amp protection circuit Updated: 2024/09/09
The breakdown of common-mode input mainly refers to the breakdown of the collector junction of the input stage. Here, the μA301 integrated operational amplifier is used to illustrate its failure and protection measures, as shown in the figure. In Figure (a), the two input terminals of the μA301 operational amplifier are connected to the base of the NPN transistor. When the collector is connected to the power supply voltage Vs and works normally, the input terminal is always negative for Vs, so there will be no forward bias between the collector and the base of the two transistors in the input stage. However. If the power supply voltage Vs is removed from the circuit, and pins ② and ③ still maintain a positive potential, that is, there is still a common-mode input voltage. The collector junction of the transistor will have a current flowing from the base to the collector. If the source resistance from pin 2 or pin ③ to the power supply is very low, the collector junction current formed at this time will be very large, so that it can damage the input stage transistor. This phenomenon occurs when the power supply voltage is removed first, but the signal source is not removed. Common-mode input will cause the integrated operational amplifier to fail and be damaged. Another situation that makes the common-mode input of the integrated operational amplifier fail is that if the signal source contains a capacitor element, when the capacitor is charged to the high potential of the signal source, the power supply voltage Vs and the signal are removed at the same time. Due to the existence of the charging voltage of the signal source capacitor, it is equivalent to the signal source voltage still existing. If this capacitor is greater than 0.1μF, the discharge current of the capacitor is enough to burn out the transistor.
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- Signal diode arrays/configurations, freewheeling diode operation
- What does a rectifier do? What is the process of rectification?
- How do Zener diodes protect circuits?
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- Causes of PCB deformation How to prevent circuit board bending and warping
- Share a Motorola amplifier circuit
- Touch circuit design and analysis
- Star finder battery indicator circuit
- LED Night Light
- Transistor leakage release protection circuit
- Relay inverse time overcurrent protection circuit a
- Low voltage circuit breaker protection circuit c
- Thyristor resistance-capacitance protection circuit b
- Repeated ground protection circuit
- The structure and working principle diagram of various protection circuits d
- The structure and working principle diagram of various protection circuits c
- AC electronic voltage regulator overvoltage protection circuit
- Thyristor overcurrent protection circuit 5
- Overcurrent protection circuit for generator low voltage start b
