Repeated ground protection circuit
Source: InternetPublisher:石榴姐 Keywords: Protection circuit ground protection BSP ground resistance Updated: 2021/08/05
In a three-phase four-wire power supply system, when the grounding resistance of a single grounding body cannot meet the requirements, multiple grounding bodies are often connected in parallel to
connect the neutral line to the earth at multiple places, which is called repeated grounding. The grounding resistance of repeated grounding bodies is not equal to the parallel value of the grounding resistance
of
each grounding body due to the shielding effect between grounding bodies . Repeated
grounding resistance is below 10fl.
Repeated grounding can avoid electric shock voltage caused by neutral line interruption, and reduce the ground voltage and electric shock risk caused by shell leakage. -
When using protective grounding - in addition to the neutral point grounding of the system, grounding must also be carried out at one or more places on the neutral line. This is called repeated grounding,
as shown in the figure.
In a 220/380V three-phase four-wire power supply system with
the neutral point directly grounded , the neutral line is required to be grounded repeatedly. If repeated grounding is not adopted
, when the neutral line is disconnected,
the zero-connection button after the disconnection point is equivalent to neither connecting to zero nor grounding. Due
to the unbalanced three-phase load and the asymmetry of the three-phase load voltage, the load
neutral point voltage is not zero, that is, there is a certain dangerous voltage on all zero-connected equipment shells after the disconnection point
; when a person
touches the equipment shell At this time, the working current will flow to the earth through the human body.
If a piece of equipment encounters a phase wire collision, the protective appliance will not operate because there is no neutral circuit , and
phase voltage values will exist for a long time on all zero-connected shells
after the disconnection point ; when a person touches
the outside of the equipment, the short-circuit current It will flow to the earth through the human body, which is very dangerous. If the grounding is repeated at one or more places, even if the neutral line is occasionally broken,
the shed line will hit the shell, and the short-circuit current will form a loop with the system through repeated grounding. Activate the protective appliance.
- Design and selection of electric control valve system drive
- Car ice warning circuit sharing
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Design of an autonomous plant watering system using ATtiny85
- What is a RADAX motor?
- JDB-LQ-TQ/2 motor full voltage starting circuit
- One-way rotation circuit of motor controlled by contactor
- Design and principle analysis of practical electric curtain remote control device
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Set timing circuit when power is on
- Self-defense anti-riot circuit
- Electronic anti-asthma circuit
- Particle clogging alarm circuit of wheat seeder
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Double detuned loop frequency discriminator circuit
- OTL low frequency power amplifier circuit
- Color display circuit
- Small current generator circuit
- Sawtooth wave generator circuit (2)
