Bias current zeroing circuit for logarithmic and log ratio amplifiers LOG101/LOG1104
Source: InternetPublisher:国民男神经 Keywords: Amplifier Updated: 2024/09/09
As shown in the figure, the bias current zeroing circuit of LOG101/104. The input current I1 and I2 of LOG101/104 are limited to the range of 100pA to 3.5mA. If the input current is greater than 3.5mA, the nonlinearity will increase; if the input current is less than 100pA, the input error will increase due to the input bias current (typical value 5pA). When the ±5V power supply is working, the current value of the input (I1 I2) is limited to 4.5mA. Two 10kΩ potentiometers R2 and R'2 are used in the circuit to zero the input bias current of the internal amplifiers A1 and A2. The internal amplifiers A1 and A2 are field effect transistor (FET) inputs, so they have FET input bias current characteristics, that is, the input bias current will double for every 10℃ increase in temperature.
- How does a series arrangement of Zener diodes affect the electrical behavior?
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- How do Zener diodes protect circuits?
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- How to calculate the value of capacitors in parallel?
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- Basic characteristics/working principles and application circuits of tunnel diodes
- How does RCCB work?
- Share a Motorola amplifier circuit
- What is the difference between high-side and low-side resistive current sensing
- Op amp driving LEDs
- Sense amplifier circuit
- Ultrasonic proximity sensor circuit
- Operational amplifier negative feedback circuit diagram
- variable gain amplifier
- An FM transmitter overvoltage protection circuit diagram
- intercom circuit
- Inventory of radio frequency interference rectification error circuits in amplifiers
- Pressure sensor measurement circuit
- Pressure measurement circuit diagram
