Resistance furnace drive and measurement circuit
Source: InternetPublisher:太白金星 Keywords: Resistance furnace measuring circuit thyristor Updated: 2021/12/02
Resistance furnace drive and temperature measurement circuit: The resistance furnace
drive and temperature measurement circuit mainly implements the temperature measurement and
driving functions of the controlled object. The circuit
is shown in Figure 27-61. A Jinchromium-Constantan thermocouple is used as the temperature sensor
, and the gain of the operational amplifier is adjusted through a potentiometer
so that the output of the operational amplifier is 5v when the temperature is 200°C.
The output of the operational amplifier is simultaneously converted into a digital quantity through A/D conversion
, and then output to the driving device after D/A conversion
. The output voltage of the D/A converter can control
the PWM duty cycle of the TL494 output. The larger this voltage is
. The longer TIA 94 outputs high level. When
the TIA94 output is high, the MOC3041 optical coupling thyristor is turned on by zero-crossing triggering, and the 220V AC power is connected in series with the following thyristor,
so the resistance furnace can be heated. When the TIA94 output is low, the MOC3041 optical coupling thyristor is disconnected, and the 220V AC power Disconnect at the same time
to stop heating the resistance furnace. In this way, we can control the heating time of the 220V- AC resistance furnace
by controlling the output of the D/A converter
, thereby controlling its temperature. There are two purposes of using MOC3041 in the heating circuit: one is to realize the isolation of strong current and weak current; the other is to realize
the zero-crossing trigger
of the bidirectional thyristor , so that the current waveform flowing through the thyristor is a sine wave and reducing the harmonics.
- How do Zener diodes protect circuits?
- How to identify common mode interference? Methods to eliminate common mode interference
- What are the types of commonly used batteries?
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- Make a flameless electronic candle using simple electronics and LEDs
- How to build a triangle wave generator using an op amp and discrete components
- What is the difference between JFET and MOSFET
- Touch circuit design and analysis
- LED Night Light
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Working principle diagram of bidirectional thyristor trigger circuit
- Thyristor furnace temperature regulation circuit
- Object detection alarm circuit with locking function
- 300A-18V three-phase thyristor voltage regulating electrolytic power supply circuit
- Thyristor switch-on delay circuit 2
- Thyristor cut-off delay circuit 4
- Thyristor overcurrent protection circuit 4
- Thyristor overcurrent protection circuit one b
- Thyristor controlled AC stabilized power supply circuit 3
- Thyristor zero trigger AC regulated power supply circuit
