Object detection alarm circuit with locking function
Source: InternetPublisher:失踪的猫 Keywords: Alarm circuit switch thyristor Updated: 2021/11/12
Shown is an object detection and alarm circuit with locking function , which can be used for anti-theft alarm. If someone invades the photoelectric detection
space, the light is blocked, the photosensitive transistor is cut off, and its collector voltage rises, causing both Di and VT1 to conduct, the thyristor is also triggered to conduct, and
the alarm light emits light. Only switch Kl can be turned off . After a while, the alarm state can be released.
- Analysis of the flow direction of transistor current
- Signal diode arrays/configurations, freewheeling diode operation
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- How to read resistor color codes? Resistor color codes illustrated
- How to build a triangle wave generator using an op amp and discrete components
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Circuit diagram of an example of differential and integral circuits
- Light controlled safety circuit switch circuit diagram
- Voice recording and playback circuit
- Photoelectric detection anti-theft alarm circuit
- Forgotten money alarm circuit
- Object detection alarm circuit with locking function
- Temperature detection control circuit of electric kettle
- Single pulse signal generating circuit f
- Single pulse signal generating circuit b
- One of the long delay circuits using integrated circuits
- Apply LOGO! Automatic gating circuit b
