Temperature control system block diagram
Source: InternetPublisher:公子李 Keywords: Temperature control system BSP natural gas MDASH Updated: 2020/11/10
(1) System configuration or The controlled object of this system is an 8-cliff annealing furnace heated by burning natural gas . The natural gas burner adopts the self-contained air mode.
Annealing furnaces are used for heat treatment of actinium materials to change the physical properties of the steel. The measured parameter is mainly temperature, and the measurement range is 0-1000-C. For this purpose,
the 8031 leather sheeting machine is used as the host machine. The principle is shown in Figure 27-46. The temperature value of the measured parameter is measured by the thermocouple Tl to obtain a millivolt signal, which
is converted into an O~5V voltage signal by the transmitter. The temperature of the eight annealing furnaces is measured by a multi-channel switch. The signal is sent to the sample/hold and A/
D converter in a time-sharing manner, and the converted digital quantity is sent to the processor through the I/O interface for analog/digital conversion. After the data is processed in the CPU
(digital filtering, scaling transformation and digital control calculations), it is sent to display on the one hand. And determine whether an alarm is needed} On the other hand, compare with the given value
, and then perform control calculations based on the deviation value. The controller output is converted into a 4-20mA signal by a ^/D converter to drive the electric actuator
to move. When the sampling value (temperature) is greater than the given value, close the natural gas valve, otherwise open the idle door. In this way, by changing the flow rate of natural gas
entering the annealing furnace , the temperature can be controlled. This system can not only perform constant temperature control, but also
control according to a certain temperature rise curve through software design . When an ultra-low or high-eye alarm occurs in an annealing furnace in the system, an audible and visual alarm signal will be emitted to remind the operator
to pay attention and take corresponding measures. 1_. -
(2) Hardware circuit of the temperature control forging system. The hardware of this system mainly includes temperature measurement, A/D conversion, microcontroller system, keyboard operating system
, temperature display circuit, alarm circuit, b/A conversion, etc.
- What does a rectifier do? What is the process of rectification?
- How do Zener diodes protect circuits?
- How does sand become chips?
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- What is power factor and three ways to improve it
- How does RCCB work?
- What is a Demultiplexer
- Summary of knowledge points of multiplexer
- Simple LED advertising light circuit
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- electromagnetic field sensor
- soil content measurement circuit
- Fish pond oxygenation reminder circuit
- Peanut and melon seeds roasting machine circuit
- Agricultural small tractor lighting circuit
- Domestic KD8041 integrated phase locked loop
- superheterodyne radio circuit
- Power phase sequence display circuit
- Motorcycle flash light circuit
- Small current generator circuit
