6-bit static display circuit
Source: InternetPublisher:清宁时光 Keywords: Display circuit 74LS244 latch BSP Updated: 2021/09/28
Shown is a 6-digit static display circuit . In the figure, 74LS244 is a bus driver. The 6-digit digital display shares a common bus. Each
LED display is connected to a latch (such as 74LS273) to latch the display code of the data to be displayed. The display code of the displayed data
is transmitted from the data bus to the input end of each latch via 74LS244, and then latched by the specified latch through the address decoder 7415138.
The bus driver 74LS244 is controlled by IOW and A9. When the output instruction is executed to make W and Ag low at the same time, the 74LS244 opens
and transmits the data on the data bus to the corresponding latch (74LS273) of each display. In the circuit shown in the figure,
the addresses of each display bit from left to right are 100H, 101H, 10ZH, 103H, 104H, and 105H.
- Does lithium iron phosphate battery need a protection board? The correct way to charge lithium iron phosphate battery
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- What is the difference between CPLD and FPGA?
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- Touch circuit design and analysis
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Circuit diagram of a differential amplifier circuit
- Voice controlled flash LED light circuit diagram
- Ultrasonic blind pathfinder circuit
- Smoking Cessation Circuit
- Inpatient pager circuit
- Rural fish farming control circuit
- Rural vegetable greenhouse lighting circuit
- Diode Balanced Mixer Circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- color discrimination circuit
- Guest arrival signal recognition circuit
