8-way switching input interface circuit
Source: InternetPublisher:两手空空 Keywords: switches interface circuits light emitting diodes Updated: 2020/09/10
The circuit circle of the 8-channel switching input interface is given. It can be seen from the figure that the switching signals sl~s8 are used to control the light-emitting diodes of the optical coupling
device to turn on and off. When the switch is closed, the LED lights up, otherwise it goes out. The phototransistor is driven by coupling,
sending a high or low level to the collector of the transistor accordingly . After using photoelectric isolation, the external interference caused by the input end can be effectively overcome. The computer reads
the 8-bit switch signal into the CPU through the effective address (/cs) and the read command (/column∞, ) .
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- An article explains the working principle of the Wheatstone bridge
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- This article will tell you the hard requirements of operational amplifiers
- Analysis of the basic principle of measuring resistance by bridge method
- Types and structures/characteristics/functions/implementations of smart sensors
- Share a Motorola amplifier circuit
- Build a musical fountain using Arduino and sound sensor
- What is a Demultiplexer
- Experimental circuit based on 4040 binary adder counter
- LED voltage measurement circuit diagram
- Particle clogging alarm circuit of wheat seeder
- Light emitting diode (LED) display driver circuit
- Battery charging status indication circuit 2
- Load open circuit indication circuit
- Logic level tester circuit 2
- Several other phase sequence discriminator circuits a
- LED tuning indication circuit
- Rectifier circuit diagram of LED assembly
- Reverse-biased GaAsP light-emitting diode used as photosensor
