Particle clogging alarm circuit of wheat seeder
Source: InternetPublisher:zht24 Keywords: Alarm circuit photodiode light emitting diode speaker Updated: 2020/10/04
Shown is the wheat seeder particle clogging alarm circuit . In this circuit, the light-emitting diode and the photosensitive diode are set at the sowing
outlet - if there is a blockage, the light received by the photosensitive diode will be blocked , so the resistance value of VD2 will increase, causing the voltage of the NE555 ⑥ pin
to rise, and the @ pin to output an alarm signal. Make the speaker sound.
- Example of LED AC drive circuit
- A white light LED power outage emergency light
- Measurement and analysis of automatic emergency lighting circuit
- Six LED stereo VU display circuit built with IC LM3915
- Laser detection and indicating device system circuit design
- Driving circuit for driving light-emitting diodes by IR53HD420
- "OR" logic element configuration circuit
- Automotive LED driver circuit diagram using LT3486
- Seven-way flashing light string circuit
- Photoelectric adjustment circuit
- AC grid powered light emitting diode circuit diagram
- Infrared remote control receiving principle block diagram
- 8-way switching input interface circuit
- Ringing signal detection circuit
- PLC input interface light emitting diode display circuit a
- Logic level tester circuit 2
- Multiple sets of light-emitting diode lantern chain circuits with different flashing frequencies a
- Photodiode Schmitt trigger
- Photodiode socket
- Photodiode circuit for optical axis angle encoder
