Load open circuit indication circuit
Source: InternetPublisher:公子李 Keywords: BSP voltage drop light emitting diode Updated: 2021/05/22
It can be used to indicate open circuit or burnout of loads (such as lamps, electric heaters,
contactor coils, etc.). The selection of the resistor Rz should ensure that the voltage drop UR
on it is not greater than
the forward voltage drop of the light-emitting diode VL, which is calculated according to the following formula:
%z-[, blue (n)
R2-.
In the formula, UF- light-emitting diode forward voltage drop (usually 1.7-2V), V;
IF- light-emitting diode operating current (usually about 10mA), A.
U.R. Generally, 3~4V is acceptable.
- Example of LED AC drive circuit
- LED acceleration and deceleration motion display composed of CD4017
- A white light LED power outage emergency light
- Electronic massage and acupuncture device circuit
- SC3071 touch step dimming light circuit
- Gas flameout alarm circuit
- WT8089 holiday lights ASIC
- Shock resistant soft start constant current LED lighting circuit
- Mains undervoltage and overvoltage alarm circuit 2
- Touch lighting switch circuit three
- electromagnetic field sensor
- Bone hyperplasia treatment circuit
- Fish farming thermostatic control circuit
- Junction field effect transistor mixer circuit
- Diode balanced amplitude modulation circuit
- Double gate field effect transistor high frequency amplifier circuit
- Voltage series negative feedback amplifier circuit
- common emitter amplifier circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Digital stopwatch display circuit
