Loopback comparator circuit
Source: InternetPublisher:黄土马家 Keywords: Comparator switch Schmitt trigger Updated: 2020/04/01
Due to the influence of environmental interference, the transmitted switch confidence will generate glitches. Switch setting signals with burrs will
have some impact on the working reliability of the computer-controlled lanthanum system . To eliminate glitches, Schmitt triggers (such as 74LS14, etc.) or integrated comparators are usually used. 'Figure 27-24 is a shaping circuit
using a comparator . This circuit has similar characteristics to a Schmitt trigger
. The sleep current is controlled by RP1 and the loop width
is adjusted by RF.
- The unidirectional conduction current of the diode, the diode and its common uses
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- How to identify common mode interference? Methods to eliminate common mode interference
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- What is a D flip-flop and how does it work?
- Simple Wired Spy Bug Circuit Built Based on IC741
- Share an interesting LED decoration project
- Structural diagram and function of sliding resistor
- Experimental circuit based on 4040 binary adder counter
- Simple LED advertising light circuit
- Rural vegetable greenhouse lighting circuit
- Diode Balanced Mixer Circuit
- Paper thickness detection circuit
- 6 data infrared signal transmitter (PT2262)
- Instantaneous water heater automatic constant temperature experimental circuit diagram
- On and off states generate fixed-width pulse circuit
- Connection circuit of thumbwheel switch ICM7217
- Electric shaver motor drive circuit
- Keying pulse signal generation circuit
- Apply LOGO! altar washing machine control circuit a
