Mechanical electric shock switch value conversion circuit c
Source: InternetPublisher:风向双子座 Keywords: switch conversion circuit contact Updated: 2021/06/08
It is a conversion circuit for mechanical contact switching. The switch conversion circuit with its own power supply in the control system is generally used in situations where the switch is installed close to
the computer control device. The power supply is DC 24V or less. Commonly used circuits have two forms: series and parallel . For parallel circuits
, when the contacts are closed The output % is high level, and Vo is low level when the contact is open. A series circuit is just the opposite. The external power supply switch value conversion
switch is suitable for situations where the switch is installed far away from the control device. When a conversion circuit in the form of a DC power supply is used , the two transistors are protective
components, and the power factor should be considered in the selection.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- Analysis of the flow direction of transistor current
- What does a rectifier do? What is the process of rectification?
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- How does sand become chips?
- Simple Wired Spy Bug Circuit Built Based on IC741
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- Simple LED advertising light circuit
- A practical automatic electronic welcome circuit
- Improved single-stage PFC conversion circuit diagram
- Celsius temperature conversion circuit diagram for thermometer
- Transformation circuit diagram
- Use 555 to form a DC step-down conversion circuit diagram
- 555 DC boost conversion circuit diagram
- DC/DC conversion circuit diagram without isolation
- Voltage doubling conversion circuit diagram 2
- Voltage doubling conversion circuit diagram 1
- MAX608 buck-boost conversion circuit diagram
- Differential input voltage-current conversion circuit 1
