DAC0832 single-bipolar voltage output interface circuit
Source: InternetPublisher:ohahaha Keywords: Interface circuit DAC0832 voltage output BSP Updated: 2020/07/22
DAC0832 is a D/A conversion chip with two input registers that can be directly connected to the computer bus. Its main performance is as follows:
resolution is 8 bits; single power supply (5-15v) i logic input level is compatible with TTL level.
The D/A converter output circuit is divided into two types: current output and voltage output. The voltage output fork is divided into two types: unipolar and bipolar. Figure 27-11 shows the interface circuit of
DAC0832 unipolar/bipolar voltage output .
In the figure, the data input terminal of DAC0832 is connected to the data bus of the computer system. The XFER and WR2 control signals are all connected to ground, and ILE is connected to
high level. When 1-z of short-circuit column KB is short-circuited. It is a unipolar voltage (O—lOV DC) output; when 1-4 and 2-3 of KB are short-circuited, it is a bipolar
(-10V—O—+10V DC) output.
- What is a FinFET? What are the advantages and disadvantages of FinFET?
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- Diode-based clipping circuit
- Basic characteristics/working principles and application circuits of tunnel diodes
- Build a musical fountain using Arduino and sound sensor
- How to build a triangle wave generator using an op amp and discrete components
- Structural diagram and function of sliding resistor
- What types of force sensors are there?
- What is the difference between high-side and low-side resistive current sensing
- Electronic thermometer circuit
- Agricultural temperature control circuit
- Egg warming circuit
- Domestic KD8041 integrated phase locked loop
- Diode balanced amplitude modulation circuit
- Crabo oscillator circuit
- Capacitive feedback oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage series negative feedback amplifier circuit
- Three primary color display circuit
