ADC0809 and PC bus interface circuit
Source: InternetPublisher:公子李 Keywords: Interface circuit ADC0809 bus interface PC Updated: 2021/04/04
The ADC0809 is an 8-bit successive approximation A/D converter with 8-channel analog switches. The 8-channel analog switch of ADC0809 can realize
8-select-1 operation, address latch and decoder channel selection signals ADDA, ADDB, ADDC. Used to select one of the 8 input channels
, the address latch enable signal ALE can connect the input channels selected by ADDA, ADDB, and ADDC to the A/D converter.
The 8-bit successive approximation state D converter
can convert the input analog signal
into an 8-bit binary representation, and the conversion
result is stored in the three-state latch output buffer
. The positive pulse signal SD\RT
can cause the A/D converter to start conversion.
After about 100tjtS, the conversion is completed
. After the conversion is completed. The EOC signal changes from low
level to high level. Notify
the CPU to read data.
The three-state latch output buffer is used
to store the conversion result when the output enable
signal OE is high level. The 8-bit conversion result is output by DO-D7. When OE is low level, the data output line DO-D7 is in a high-impedance state.
Since the ADC0809 has a three-state latched output buffer, it can be connected directly to the system bus. In order to facilitate or simplify the interface circuit
design, the interface with the system is usually implemented through a universal parallel interface chip. The circuit shown in the figure is a circuit in which ADC0809 is connected to a PC through the programmable parallel interface
chip 8255A .
- How are diodes made using semiconductors?
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- Principle set of zero-crossing detection circuit advantages and disadvantages
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Beautiful crown wreath made with LED
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- Structural diagram and function of sliding resistor
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- LED lights that “drain” battery power
- Experiment and production of NE555 time base integrated circuit
- Bidirectional DC motor control interface circuit
- Switching interface circuit in timing query mode
- AD574 and PC bus interface circuit
- Indoor unit microprocessor communication interface circuit
- Interface circuit between CMOS and PMOSb
- Interface circuit between CMOS and NMOS b
- Interface circuit between CMOS and switching amplifier a
- Interface circuit between power supply coupler and digital circuit
- Interface circuit between power supply coupler and transistor a
- Mechanical switch contacts and CMOS interface circuit
