Collector AM circuit
Source: InternetPublisher:ghaytweyhtoo Keywords: AM Circuit Updated: 2024/08/30
The figure above is a collector amplitude modulation circuit. The equal-amplitude carrier generated by the high-frequency carrier oscillator is added to the transistor base through T1. The low-frequency modulation signal is coupled to the collector through T3. C1, C2, and C3 are high-frequency bypass capacitors, and R1 and R2 are bias resistors. The LC parallel circuit of the collector resonates at the carrier frequency. If the static operating point of the transistor is selected in the curved part of the characteristic curve, the transistor is a nonlinear device. Because the collector current of the transistor changes with the modulation voltage, the two signals in the collector are amplitude modulated due to nonlinear effects. Since the LC resonant circuit is tuned to the base frequency of the carrier, an amplitude modulated wave output can be obtained at the secondary of T2.
- The unidirectional conduction current of the diode, the diode and its common uses
- How are diodes made using semiconductors?
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- How to identify common mode interference? Methods to eliminate common mode interference
- Types and structures/characteristics/functions/implementations of smart sensors
- Causes and solutions for noise in digital Class D amplifiers
- What is power factor and three ways to improve it
- How to build a triangle wave generator using an op amp and discrete components
- collector amplitude modulation circuit
- Amplitude modulation circuit composed of MC1496
- ring amplitude modulation circuit
- Diode balanced amplitude modulation circuit
- Series base amplitude modulation circuit
- Amplitude modulation circuit using three transistors
- Carrier suppression amplitude modulation circuit using analog switches
- Emitter amplitude modulation circuit
