Schematic diagram of the working principle of the motherboard clock circuit
Source: InternetPublisher:清宁时光 Keywords: Clock circuit BSP clock signal Updated: 2020/09/30
Shown is a schematic diagram of the working principle of the motherboard clock circuit.
The 3.3 V or 2.5 V voltage in the figure is a prerequisite for the clock circuit to work normally and is the voltage source of the clock signal generator chip . After 3.3 V or 2.5 V is sent to the clock generator chip through the resistor, the clock generator starts to oscillate and the 14.318 MHz crystal is used as
the resonant component
of the clock generator .
When the motherboard is working normally, the two pins of the crystal oscillator should have about 1 V DC voltage.
Usually, the 3.3 V voltage is directly provided by the orange line of the AIX power supply, and the 2.5 V voltage is obtained from the 3.3 V voltage through the DC regulator.
When the 3.3 V and 2.5 V supply voltages are started, the internal oscillator of the clock signal generator chip starts to work and forms a 14.318 MHz
clock signal. After the signal is processed by its internal upconverter, downconverter, etc., it obtains clock frequencies of different values (such as 14.318 MH2, 33 MH,
48 MHz, etc.), and then outputs through the pin of the clock signal generator chip, and then passes through the peripheral of the chip . Current-limiting small-value resistors (22n, 33n
, etc.) are then sent to each module of the motherboard to provide clock frequency.
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- Signal diode arrays/configurations, freewheeling diode operation
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- What is an ac to dc transformer in circuit design
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- Important things to know about PCB routing and how to design the right routing for your PCB
- Build a musical fountain using Arduino and sound sensor
- How to build a triangle wave generator using an op amp and discrete components
- LED Night Light
- FL52C4 induction electronic greeter
- electromagnetic field sensor
- Electric massager circuit
- Crop anti-frost circuit
- Rural fish farming control circuit
- Agricultural spraying and insecticide control circuit
- Farmland irrigation automatic control circuit a
- Frequency modulator composed of NE566
- Varactor Diode Frequency Modulator
- Various signal generator circuits
- Sine wave signal generator circuit
