MAX1555 reference design circuit | battery charger application circuit
Source: InternetPublisher:sigma Keywords: Diode power battery circuit Updated: 2020/10/16
The MAX1555 charges a single-cell lithium-ion (Li+) battery via USB and AC adapter power. They require no external FETs or diodes and can accept input voltages up to 7V. This article mainly introduces the characteristics, application range, reference design circuit and circuit analysis of MAX1555 to help you shorten design time.
MAX1555 features: Charging from USB port or AC adapter; automatic power switching when AC adapter is plugged in; charging status indicator
Typical applications of MAX1555: cellular phones; digital cameras; wireless applications
MAX1555 reference design application circuit:
![1.png](http://www.eeworld.com.cn/circuit/upload/227078252739d559701cc5c02bcfa89f/3825db6876323a2e1a8eeee02b0c32a1.png)
Figure 1 MAX1555 reference design diagram
The MAX1551/MAX1555 charge a single-cell Li+ battery from both USB and AC adapter sources, enabling portable users to forgo carrying a wall cube. These devices operate with no external FETs or diodes, and accept operating input voltages up to 7V.
- 5 Converter Topologies for Integrated Solar and Storage Systems
- A very convenient small power supply circuit to share
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Transformerless AC-DC constant current LED driver circuit
- LNK304 non-isolated LED light string driver circuit
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Dual forward converter schematic diagram
- Voltage-current converter constructed with XTR110
- LM317T voltage regulation adjustable circuit diagram explanation
- How to avoid electrical stress in chip design, do you know?
- Littelfuse Low Capacitance TVS Diode Array Analysis
- How to judge the positive and negative poles of diodes
- Diode tester circuit
- Diode Ring Mixer Circuit
- High frequency signal input switch circuit b
- High frequency signal input switch circuit a
- FM modulator strong-weak signal switching circuit c
- Improved multivibrator circuit c
- Diode spark suppression circuit a
