MAX233-233A multi-channel data interface circuit
Source: InternetPublisher:赔钱虎 Keywords: Interface circuit data interface BSP data transmission Updated: 2021/04/14
MAX233/233A multi-channel data interface circuit , which has a dual output and dual input drive circuit, is used for data transmission
in small digital products and multimedia equipment .
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- What does a rectifier do? What is the process of rectification?
- What is a D flip-flop and how does it work?
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- Working principle/advantages/disadvantages/size of optical fiber
- Ceramic filter structure/working principle/characteristics/application
- Make a flameless electronic candle using simple electronics and LEDs
- LED lights that “drain” battery power
- LED Night Light
- Circuit diagram of a differential amplifier circuit
- Set timing circuit when power is on
- Excellent performance household inverter power supply circuit
- stuttering correction circuit
- soil content measurement circuit
- Biogas concentration detection line
- Farmland drainage automatic control circuit
- Simple AGC circuit in transistor radio
- Diode square rate detection circuit
- Amplitude modulation circuit composed of MC1496
- Second-order active band-stop filter circuit
