Interface circuit composed of 8255A and single chip microcomputer
Source: InternetPublisher:已注销 Keywords: MCU interface circuit Updated: 2024/08/29
The figure below shows the interface circuit between 8255A and MCU. In 8255A, D7~D0 are used as address ports, AO~A1 are used as address ports, WR (the inverse), RD (the inverse), CS (the inverse), and RESET are used as control ports.
Because all registers and I/O ports of 8255A have corresponding read and write addresses, it is possible to address each I/O port and control word register of 8255A. 8255A will work only when A15~A8 is 01111111 and A6~A2 is 11111.
PA address: 7F7CH.
PB address: 7F7DH.
PC address: 7F7EH.
Control word address: 7F7FH.
- How to connect ADC to 8051 microcontroller?
- Commonly used MCU reset circuit sharing
- SN75370 Dual MOS Memory Interface Circuit
- Interface circuit composed of photocoupler
- Interface circuit between 51 single chip microcomputer and MAX7219
- Interface circuit composed of 8051 single chip microcomputer and 74LS165
- How to Design a Fan Cooling System Using a Microcontroller
- Use printer port to make programmable frequency generator circuit
- Circuit diagram: 8051
- 815 motherboard
- CNC machine tool and computer communication circuit diagram design
- Analysis of internal reset circuit diagram of microcontroller
- Dual audio decoding electronic circuit
- Stepper motor drive circuit composed of LB1836M
- Two types of negative voltage generation circuit diagrams of single-chip microcomputer
- Minimum system interface circuit based on AT89C52 microcontroller
- Keyboard-display interface circuit
- Contact relay output control interface circuit
- Switching interface circuit in timing query mode
- Optoelectronic interface circuit between single-channel DA chip DAC0832 and microcontroller
