Interface circuit between AT89C51 and RS-232
Source: InternetPublisher:elleny Keywords: Interface circuit AT89C51 Updated: 2024/08/19
The RS-232 serial interface circuit is shown in the figure below. It is mainly used for communication between PC and single-chip microcomputer. Here, the 2nd, 3rd and 5th pins of the serial port are needed for communication, corresponding to the receive, send and ground signals respectively, to complete the sending and receiving of data.
At the same time, in order to realize the connection between the microcontroller and the PC, MAX232 is used as the serial port level conversion chip to complete the conversion between the TTL level of the microcontroller and the RS-232 level.
- How to use 8051 microcontroller to control stepper motor?
- How to design a pet activity tracker using XIAO BLE Sense
- Schematic diagram of MCU SPI interface circuit
- Application circuit of CSJ-R05B and single chip microcomputer
- Interface circuit composed of 8255A and single chip microcomputer
- Interface circuit between 51 single chip microcomputer and MAX7219
- How to use ESP8266 to design a portable air quality monitoring station
- How to use ADXL335 to realize the design of gesture control robot
- Circuit diagram: 8051
- 815e motherboard
- Interface circuit between DAC0832 and 8-bit CPU
- CPU and decoding chip memory, SD memory card socket interface circuit
- Calendar and clock display interface circuit
- Interface circuit between CMOS and switching amplifier a
- Interface circuit between power supply coupler and digital circuit
- Power supply coupler-thyristor interface circuit c
- Interface circuit between power supply coupler and triode b
- Interface circuit between power supply coupler and transistor a
- Interface circuit between CMOS and transistor
- Interface circuit between CMOS and THL
