Four bedrooms and two living rooms circuit diagram
Source: InternetPublisher:念念Brown Keywords: Circuit diagram air conditioner socket Updated: 2021/09/18
The power distribution system of four rooms and two living rooms is as shown in the figure. There are 12 branches of power supply designed, including lighting , electrical equipment sockets , and air-conditioning sockets
. Two of them are used for lighting . If one fails, the other can supply power in time for maintenance. There are 7 sockets , which are installed in the living
room 1, bedroom 4, kitchen 1, and balcony 1. This ensures that various electrical appliances can be used at the same time without overloading the circuit and can play a diversion role. The 3-way air conditioning circuit is sufficient. If a cabinet air conditioner
with a larger capacity is installed in the living room , the other 2 circuits can be used as backup.
- Measurement and analysis of automatic emergency lighting circuit
- LED Signage with RS232 Port Operation Guide
- A light fence circuit diagram with LDR
- Driving circuit for driving light-emitting diodes by IR53HD420
- Lighting lamp voltage stabilizing circuit (2)
- Desk lamp dimming soft switch circuit
- Microwave Doppler warning circuit
- Large light emitting diode display circuit
- SH-803R holiday lights ASIC
- Touch lighting switch circuit three
- Electronic circuit diagram tips
- Tube crossover balanced inverter circuit diagram
- One-digit display timer circuit diagram
- Electronic frostbite treatment device circuit diagram
- AC grid powered light emitting diode circuit diagram
- CPU and decoding chip memory, SD memory card socket interface circuit
- Power timing socket hardware circuit based on PIC microcontroller
- Dimming and temperature regulating socket circuit
- 555 constitutes a 1h timing socket
- A single-connection switch controls a light and is connected to an additional outlet
