Schematic diagram of speed switching circuit hydraulic system
Source: InternetPublisher:三岁就很酷 Keywords: Hydraulic system system principle Updated: 2021/05/16
The following takes the speed switching circuit as an example to illustrate the writing of PI.C control program in the hydraulic system experiment. The principle diagram of the hidden pressure of the speed-changing Jianpu Road
is shown in the figure.
The action cycle is as follows:
1) When energized, 1ZT has power and the hydraulic cylinder realizes fast forwarding.
2) When the travel switch 2XK is pressed, 3ZT is powered, and the oil returns to the speed control valve l to achieve one-work progress.
3) When the travel switch 3XK is pressed, 4ZT is powered and the oil returns to the speed control valve 2 to realize the second work.
4) When the travel switch 4XK is pressed. 1ZT is powered off, 2ZT is powered on, and the oil circuit is reversed to achieve fast rewind.
5) When the travel switch Ixl< is pressed, 5ZT has power and the system realizes unloading.
(2) The I/O allocation of the PLC is based on the hydraulic schematic diagram of the experimental circuit and the control requirements for the action process. The 1/0 points of the PLC are allocated
and defined.
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Tutorial on making your own remote-controlled robotic arm
- Design of an autonomous plant watering system using ATtiny85
- Build a glove-controlled robotic arm
- How to build a simple tachometer using an infrared reflectance sensor
- DC motor drive circuit composed of L293D
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Motor self-starting circuit
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- An experimental model of an infrared radio alarm
- Pyroelectric automatic door control circuit
- Flashing wall light control circuit
- Electromagnet control circuit
- Table printing machine control circuit
- Automatic tuning control circuit
- Relay control circuitb
- Relay control circuit a
- Voltage servo motor and control circuit
- audio signal control circuit
- Basic structure of power factor control circuit
