Function generator controlled by DAC
Source: InternetPublisher:酷到被通缉 Keywords: DAC function generator triangle wave Updated: 2021/02/27
Shown is a function signal generator controlled by DAC08'30 chip. DAC 0830 converts the digital signal (D) into an analog
signal to control the IC2-A oscillator to output a triangular wave signal . The triangular wave is shaped by the IC2-B and outputs a square wave signal. At the same time, the triangular
wave signal can output a sine wave signal through the differential amplifier and operational amplifier.
- Does lithium iron phosphate battery need a protection board? The correct way to charge lithium iron phosphate battery
- What does a rectifier do? What is the process of rectification?
- FPGA Features and Architecture
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- What are the classifications of filters?
- Basic characteristics/working principles and application circuits of tunnel diodes
- Analysis of three simple electronic dice circuits
- Summary of knowledge points of multiplexer
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Interface circuit between DAC1210 and PC
- Absolute value function generator circuit with controllable output signal polarity
- Pulse function generator circuit with very large (or very small) duty cycle
- Function generator switch-on circuit
- Triangular wave signal generator circuit composed of LM359
- Triangular wave and square wave generator circuit
- Triangular wave-rectangular wave generator
- Tube amplifier Japanese TDA1541A DAC power supply V1 circuit diagram
- Tube amplifier TDA1541NOS DAC--2 circuit diagram
- DAC circuit diagram of tube amplifier pmd100+1702
