Debug-free FM transceiver circuit composed of BA1404 TDA7021
Source: InternetPublisher:已注销 Keywords: FM transceiver circuit Updated: 2024/08/07
The biggest feature of this circuit is that it is simple to make and does not require debugging. In particular, the receiving circuit does not use double variable capacitors and intermediate frequency transformers. The circuit is ready to be assembled, which is very suitable for radio enthusiasts to make their own. Figure (a) is the receiving circuit; Figure (b) is the transmitting circuit.
When the circuit transmits a signal with a frequency of 88 to 108 MHz, L2 is wound with Φ0.65 mm enameled wire into an air-core coil with an inner diameter of 8 mm and 10 turns. L3 is wound with Φ0.65 mm enameled wire into an air-core coil with an inner diameter of 6 mm and 8 turns.
- A cheap and easy-to-make infrared TV signal repeater
- Production of a FM wireless microphone
- Pocket Wireless Microphone
- Homemade FM wireless microphone for teaching
- RX3408 FM/FSK 500~20 MHz Receiver
- MICRFl03 ASK 1 GHz~800 MHz Transmitter
- RF2919 ASK/OOK 915/868/433 MHz Receiver
- CYWUSB6932 GFSK 2.4 GHz Wireless USB Interface Transmitter
- RF2516 AM/ASK/OOK 433/315 MHz Transmitter
- F05A/B/C Series AM 433/315 MHz RF Transmitter Module
- USB communication circuit
- Indoor unit communication circuit
- Two-way communication circuit circuit diagram
- Long distance serial communication circuit
- CAN bus communication circuit
- Wireless transmitter circuit diagram
- Time division multiplexing stereo decoder circuit
- Design of wireless transmitting and receiving circuit based on Bluetooth
- Fiber optic transceiver circuit diagram
- Square wave generation circuit
