DC motor drive circuit
Source: InternetPublisher:闪电杰克 Keywords: DC motor drive circuit BSP Updated: 2021/05/26
Circuit working principle: The feedback signal is sampled from the 3W current sampling resistor R. The two ends of
are connected to the two inputs of the op amp, and the signal is forced to flow through R. The current remains
unchanged. The calculation formula of the output current is as follows:
Iout=(Vin/Rsc) (R2/R1)
Select R2=R4=lk Ω, R1=R3 =100 k Ω, Rsc=0.25 Ω. In this way,
when the input voltage is 6.25 V, an output current of 2.5 A can be given. R1 to R4
use resistors with an error of 1% and 0.25 W, and the operational amplifier should be fixed on the heat sink.
- Analysis of the working principle of the sound and light controlled delay switch circuit
- A simple magnetic switch circuit sharing
- Model rocket launch controller circuit
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Design and analysis of the principle of automatic power-off switch during power outage
- Design and manufacture of three-phase motor protection circuit
- A novel and practical power line anti-theft and cutting alarm circuit
- Infrared detection alarm
- Water supply reminder after water outage
- Voice controlled flash LED light circuit diagram
- Fish farming thermostatic control circuit
- Mixer built with analog multipliers
- Integrated synchronous detector composed of analog multiplier MC1596
- collector amplitude modulation circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- common emitter amplifier circuit
- Color display circuit
- Power phase sequence display circuit
- Digital stopwatch display circuit
