water level indication circuit
Source: InternetPublisher:失踪的猫 Keywords: Electrode BSP Updated: 2021/05/01
The indicator is a water level indication circuit, which is composed of a
water level detection electrode and a voltage comparator in the water tank. When the water exceeds a certain
electrode, the voltage of the corresponding electrode (acted to the ground through the resistance of the water) will decrease. The connected voltage is relatively low and a high level will be output, causing the connected
LED to light up. According to the indications of the four LEDs , thus indicating the level of water level in the water tank.
For example, when water is injected into the permanent tank and the water level rises to the D electrode, the resistance of the water connects the two electrodes D and E. At this
time, the voltage of the reverse input terminal ② of the operational amplifier IC D is lower than +5 V, pin ① outputs a high level, causing the light-emitting diode VD4 to conduct forward and emit
light, thereby indicating that the water level has reached the D electrical connection. As the water level continues to increase, the detection electrodes C, B, and A in the water tank are connected to the circuit
in sequence
, causing the operational amplifiers ICC, ICB, and IC A to output high levels one after another, thus lighting up the diodes VD3, VD2, and VD1 in sequence. , when all four
diodes light up, it indicates that the water tank is full.
- Which one is better, NPN or PNP transistor?
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- How does sand become chips?
- FPGA Features and Architecture
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- Simple Wired Spy Bug Circuit Built Based on IC741
- Tutorial on building a NOT gate using BJT transistors
- How to install the accelerometer
- electromagnetic field sensor
- Electronic anti-asthma circuit
- Farmland drainage automatic control circuit
- Farmland irrigation automatic control circuit a
- DC ammeter
- collector amplitude modulation circuit
- Parallel crystal oscillator
- Crabo oscillator circuit
- Motorcycle flash light circuit
- Various signal generator circuits
