Subtraction circuit
Source: InternetPublisher:黄土马家 Keywords: Arithmetic circuit BSP arithmetic unit Updated: 2021/12/13
Shown is a subtraction circuit. The voltage is added to
the inverting input terminal of the operational amplifier through Ri, the voltage is divided by R2 and R3 and then added to the non-inverting input terminal,
and the pump is fed back to the inverting input terminal through Rf. In order to
balance the two input terminals of the operational amplifier, }Rl/,RrRzllR3.
The output voltage of the subtraction circuit is equal to the difference between the two input voltages, thus realizing the subtraction of
the two input signals . The subtractor fork is called a
differential input arithmetic circuit and has a suppression effect on common-mode signals. Therefore, the subtractor can not only subtract signals, but can also be used to amplify signals
containing common-mode interference .
- How to identify common mode interference? Methods to eliminate common mode interference
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- DIY a decorative lamp
- Important things to know about PCB routing and how to design the right routing for your PCB
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Experiment and production of NE555 time base integrated circuit
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- An example of proportional integral circuit diagram
- Circuit diagram of a differential amplifier circuit
- Set timing circuit when power is on
- Bone hyperplasia treatment circuit
- Smoking Cessation Circuit
- Fish pond oxygenation reminder circuit
- Rural vegetable greenhouse lighting circuit
- Farmland irrigation automatic control circuit b
- Integrated synchronous detector composed of analog multiplier MC1596
- Diode square rate detection circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Guest arrival signal recognition circuit
