Safe anti-theft alarm circuit
Source: InternetPublisher:通通 Keywords: Anti-theft alarm circuit BSP piezoelectric sensor Updated: 2020/03/03
Shown is a safe anti-theft alarm circuit ,
which is mainly
composed of voltage sensor BZ1, tilt sensor
B22, temperature sensor RT, voltage comparator IC 3 and other components. The piezoelectric sensor BZ1 is connected to the input end of the voltage comparator IC3-1. When it is vibrated, an electrical signal will be generated. The electrical signal
is amplified by IC3-1 and IC3-2 and then passes through the OR gate circuit IC4-1 and IC4- 2 to drive transistor VT1. The conduction of VT1 will cause the relay to operate, and the contacts of the relay will turn on
the alarm buzzer.
There is also a tilt sensor (mercury switch) on the safety lock. When someone moves the safe, the mercury switch on the safety lock is turned on, and
the @ pin of the OR gate circuit IC4-1 also outputs a high level to alarm.
The third sensor is a temperature sensor. When the safe is subject to high heat, the resistance value of the thermistor RT decreases, and pin 8 of IC3-3 outputs
a high level and adds it to the OR gate circuit IC 4-1. Activate the alarm circuit.
- Principle set of zero-crossing detection circuit advantages and disadvantages
- RC filter explained in detail
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- What is power factor and three ways to improve it
- Simple Wired Spy Bug Circuit Built Based on IC741
- Working principle/advantages/disadvantages/size of optical fiber
- Share an interesting LED decoration project
- What is the difference between JFET and MOSFET
- Simple LED advertising light circuit
- LED Night Light
- Motor overcurrent protection circuit
- Analysis of rectifier circuit types and principles
- Soil water shortage prompt circuit
- AC voltmeter
- Varactor Diode Frequency Modulator
- Series crystal oscillator
- Parallel crystal oscillator
- common emitter amplifier circuit
- Digital stopwatch display circuit
- Home appliance repair signal generator circuit
