Home > Basic Circuits >Sensor Circuits > Automatic LED billboard decorative light circuit at night
Source: InternetPublisher:抄写员 Keywords: LED BSP resistor Updated: 2020/02/16
47. Automatic <strong>LED</strong> billboard decorative light<strong>circuit</strong> at night.gif
Shown is the automatic LED billboard decorative light circuit at night. Photoresistor RG is used to sense light intensity.
    After the AC 220 V voltage is stepped down, rectified, stabilized and filtered, a DC voltage of about 7.5 V is output to power the components in the circuit . At the same time,
the bridge rectifier stack VDO and the current limiting resistor Rz drive the two-pin tube group VD to emit light.
    When the light intensity is high, the photoresistor RG is in a low resistance state, VT1 is in a cut-off state, VT2 cannot be turned on,
there is no voltage at both ends of the capacitor c3, and the diode group VD does not emit light; when the light intensity is weak at night, the photoresistor The resistance value of emitter RG increases. When it rises to
the set resistance value, the base of VT1 obtains a voltage value sufficient to turn it on, and its emitter outputs the trigger voltage to turn on VT2, and the light-emitting
diode group VD is turned on. Light up.
