Photoelectric control lighting circuit using photosensitive sensor
Source: InternetPublisher:桂花蒸 Keywords: Optoelectronics lighting Updated: 2021/06/17
Shown is a photoelectrically controlled lighting circuit using a photosensitive sensor (photoresistor) .
This circuit is suitable for street lights, door lights, corridor lighting and other occasions. During the day, the bulb in the circuit does not light up; when the light is weak,
the bulb can light up automatically.
When the light is strong during the day, the resistance value of the photoresistor RG is small, then the input terminal of ICI is low level and the output terminal is high level. At this time,
VDI is turned on, and the ② and @ pins of IC2 are high level, ③ The pin outputs a low level, and the light-emitting diode VD2 lights up, but the relay coil KA does not close and
the bulb L does not light up.
When the light is weak. The resistance value of k becomes larger. At this time, the voltage at the input terminal of IC1 becomes high level and the output is low level, causing VD1 to cut off.
At this time , the capacitor cl begins to charge under the action of the external DC power supply, causing the potential of IC2② and ⑥ pins to gradually increase. reduce. @ pin outputs a high level, causing
the relay coil KA to close, driving the normally open contact to close, and the light bulb L is powered on and lit.
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- An article explains the working principle of the Wheatstone bridge
- This article will tell you the hard requirements of operational amplifiers
- Types and structures/characteristics/functions/implementations of smart sensors
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- Causes of PCB deformation How to prevent circuit board bending and warping
- Build a musical fountain using Arduino and sound sensor
- Circuit diagram of a differential amplifier circuit
- Laser flashlight circuit diagram
- Photoelectric control switching circuit composed of photoresistor lamp elements
- Photoelectric control motor drive circuit
- Photoelectric control RS trigger
- Punch photoelectric control safety device circuit four
- JG series photoelectric relay circuitb
- NE555 flashing light circuit diagram
- Optoelectronic component control amplifier circuit
- Mains powered photoelectric smoke alarm circuit diagram
- Street light electrical control circuit
