Photoelectric control motor drive circuit
Source: InternetPublisher:newlandmark Keywords: Optoelectronics motors drive circuits Updated: 2021/08/19
Shown is the photoelectric control motor drive circuit . The motor is powered by AC 22QV power supply, and there is a relay switch in the power supply circuit
. Relays K1 and K2 are controlled by the circuit . The phototransistor vl is used as a light sensor. As long as the light and dark change once, the circuit will
act once and the motor will run for a certain period of time. This time is determined by the delay time of the IC2 and IC4 monostables.
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- Signal diode arrays/configurations, freewheeling diode operation
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- An article explains the working principle of the Wheatstone bridge
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- RC filter explained in detail
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Analysis of three simple electronic dice circuits
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Photoelectric control RS trigger circuit
- Photoelectric control relay circuit
- Photoelectric stabilized power supply circuit
- Punch photoelectric control safety device circuit one a
- Photoelectric gun circuit
- Photometry circuit diagram using AC amplifier
- Using photoelectric thyristor as overvoltage protection circuit
- Voice control lighting circuit circuit diagram
- Photoelectric insect killer circuit
- Light controlled thyristor photoelectric safety protector
