Soil moisture detection circuit
Source: InternetPublisher:风向西瓜 Keywords: Soil moisture detection humidity detection circuit LED BSP Updated: 2021/04/21
Shown is a common soil moisture detection circuit. The sensor device of this circuit is composed of a humidity probe sensor.
This circuit mainly indicates the different moisture status of the soil through the display status of two light-emitting diodes: when both diodes do not emit light or emit
dim light, it means that the soil moisture is suitable for the growth of the plants; when LED 1 is on and LED2 is not on When LED1
is off but LED2 is on, it means the soil moisture is too low.
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- How to identify common mode interference? Methods to eliminate common mode interference
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- How to read resistor color codes? Resistor color codes illustrated
- Types and structures/characteristics/functions/implementations of smart sensors
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- What is the difference between high-side and low-side resistive current sensing
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- stuttering correction circuit
- Rural vegetable greenhouse lighting circuit
- Crabo oscillator circuit
- Capacitive feedback oscillator circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- common emitter amplifier circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Three primary color display circuit
- Sawtooth wave generator circuit (2)
