Schmidt humidity sensor
Source: InternetPublisher:萌面大虾 Keywords: Schmidt humidity sensor BSP Updated: 2021/02/11
Humidity reflects the degree of dryness and humidity of the atmosphere. Measuring environmental humidity
is very important for industrial production, weather forecasting, food processing, etc.
Humidity-sensitive sensors are elements that are sensitive to the relative humidity conversion of the environment.
Components, usually composed of wetted layers, metal electrodes, leads and substrate substrates
The figure shows a Schmidt humidity sensor , a
Schmidt circuit composed of three-plate tubes VT1 and rr2 . When the ambient
humidity is small, the resistance value of the humidity-sensitive resistor RS is larger, and the input end of the Schmidt
circuit is at low voltage. In flat state, VT1 is cut off, VT2
conduction is at low level, and the red LED lights up; when
the humidity increases, the RS resistance value decreases, the VT1 base current increases, v, ri collector current increases, and the load resistor Rl The voltage drop increases,
causing the base voltage of VT2 to decrease and the collector current of VI2 to decrease. Due to the positive feedback of the circuit, VT1 is saturated and turned on, VT2 is cut off, making
the collector of VI2 close to the power supply voltage, and the red light-emitting diode goes out. By the same token, when the humidity decreases, another positive feedback process occurs, and
the Jingmit circuit quickly flips to the VT1 cutoff. VT2 is in the saturated conduction state, and the red LED changes from off to on.
- Signal diode arrays/configurations, freewheeling diode operation
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- FPGA Features and Architecture
- Working principle and truth table of JK flip-flop
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- Ceramic filter structure/working principle/characteristics/application
- Make a flameless electronic candle using simple electronics and LEDs
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Simple LED advertising light circuit
- Motor overcurrent protection circuit
- High-efficiency speaker circuit for rural stage
- Particle clogging alarm circuit of wheat seeder
- Poultry warming temperature control circuit
- Junction field effect transistor mixer circuit
- Frequency modulator composed of NE566
- base amplitude modulation circuit
- Wien bridge oscillator circuit
- Voltage series negative feedback amplifier circuit
- Motorcycle flash light circuit
