Capacitively coupled two-stage amplifier connected by two common-emitter transistor amplifiers
Source: InternetPublisher:三月小雨 Keywords: transistor amplifier coupled common emitter Updated: 2021/08/27
Shown is a capacitively coupled two-stage amplifier formed by connecting two common-emitter (e) transistor amplifiers to achieve higher amplification
. The output of the front-stage common-emitter (e) transistor amplifier is coupled to
the input end of the subsequent-stage common-emitter (e) transistor amplifier
through the capacitor c2. The coupling function of the capacitor is to pass AC and block DC. Using capacitor coupling can prevent the DC bias voltage of a certain amplifier stage from affecting
the DC bias voltage of the next stage. However, the AC signal can be directly sent to the next stage through the coupling capacitor . level amplifier.
- What is the difference between MOSFET and BJT? Which one is better between MOSFET and BJT?
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- How to read resistor color codes? Resistor color codes illustrated
- Types and structures/characteristics/functions/implementations of smart sensors
- What are the classifications of filters?
- RC filter explained in detail
- Beautiful crown wreath made with LED
- What is the difference between JFET and MOSFET
- Make a simple AM radio with digital circuit
- LED Bicycle Lights
- Set-base coupled monostable circuit
- Common mode signal emitter coupling differential amplifier circuitb
- Common mode signal emitter coupling differential amplifier circuit a
- Combination of source ground and emitter follower
- Common base transistor amplifier unit circuit a
- Emitter coupled flip-flop circuits and applications
- Common emitter - common collector amplifier
- Souyiji mid-amplifier circuit using RC coupling and concentrated filter
- Voltage Controlled ECL (Emitter Coupled Logic) Integrated Circuit Crystal Oscillator Generator Circuit
- Stabilized current and voltage stabilized transistor amplifier power supply circuit diagram
