Common collector amplifier circuit b
Source: InternetPublisher:刘德华河北分华 Keywords: Amplification circuit common collector BSP resistor Updated: 2020/10/14
(1) The structure and key components of the common collector amplifier circuit
are as shown in the figure. The key components of the common collector amplifier circuit are basically the same as those of the common emitter amplifier circuit. There are two differences:
one is that the collector The resistor & Mu goes to the emitter (denoted by Van), and the second is that the output signal is no longer taken from the collector but from the emitter.
In this circuit, two bias resistors L and R are connected to supply power to the base of the transistor (b) through the power supply: Rc is
the load resistor of the emitter of the transistor (e); both capacitors serve as communication isolation. DC-acting coupling capacitor: resistor Rr. is the load resistor for loading the
output signal .
Like common emitter transistor amplifiers, the biggest difference between NPN and PNP transistor amplifiers is the difference in power supply.
Since the internal resistance of the power supply of the transistor amplifier circuit is very small, the positive and negative electrodes are equivalent to a short circuit for AC signals. Alternating current is equivalent
to the power supply, which means that the collector of the transistor (c) is equivalent to ground. The input signal is loaded between the base (b) and emitter (e) of the transistor and
the load resistor Gen, which is equivalent to loading between the base (b) and collector (c) of the transistor. The output signal is taken from the transistor. The emitter (e) of the
transistor is equivalent to being taken between the emitter (e) and the collector (c) of the transistor. Therefore, the collector (c) is the
common terminal of the input signal and the output signal, so it is called a common collector . Electrode amplifier circuit .
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- How are diodes made using semiconductors?
- What is an ac to dc transformer in circuit design
- Analysis of the basic principle of measuring resistance by bridge method
- How does sand become chips?
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- What are the classifications of filters?
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- Simple Wired Spy Bug Circuit Built Based on IC741
- Important things to know about PCB routing and how to design the right routing for your PCB
- Smoking Cessation Circuit
- Inpatient pager circuit
- Poultry warming temperature control circuit
- Farmland irrigation automatic control circuit b
- Frequency modulator composed of NE566
- Varactor Diode Frequency Modulator
- collector amplitude modulation circuit
- Parallel crystal oscillator
- Differential Amplifier Circuit
- Sawtooth wave generator circuit (1)
