Common emitter amplifier circuit a
Source: InternetPublisher:D先生 Keywords: Common emitter amplifier circuit BSP resistor output signal Updated: 2021/12/16
(1) The structure and key components of the common emitter amplifier circuit
The common emitter amplifier circuit refers to the basic amplifier circuit with the emitter (e) as the common ground terminal for the input signal and the output signal . The basic structure of the circuit
is shown in Figure 1-1. Its key components include a triode, four resistors and two capacitors.
The bias resistors 1 and R in the circuit supply power to the transistor base (b) through the power supply; the load resistor Re
supplies power to the transistor collector (c) through the power supply; both capacitors function to communicate AC and isolate DC. coupling capacitor; resistor RL is the
load resistor carrying the output signal .
The biggest difference between NPN type and PhrP type transistor amplifiers is the power supply: for amplifiers using NPN transistors, the power supply
is the positive power supplied to the collector of the transistor (c); for amplifiers using PNP transistors, the power supply is supplied from the negative power supply. into
the collector of the transistor (c).
The input signal is added between the base (b) and emitter (e) of the transistor, and the output signal is taken from
between the collector (c) and emitter (e) of the transistor. It can be seen that the emitter (e ) is the common terminal of the input signal and the output signal , so it is called a common emitter transistor amplifier and
is often used in transistor voltage amplification circuits.
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- Analysis of the flow direction of transistor current
- Which one is better, NPN or PNP transistor?
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- Beautiful crown wreath made with LED
- Share an interesting LED decoration project
- Build a musical fountain using Arduino and sound sensor
- Tutorial on building a NOT gate using BJT transistors
- Homemade air conditioner outdoor unit shutdown indicator
- Smoking Cessation Circuit
- High-efficiency speaker circuit for rural stage
- Peanut and melon seeds roasting machine circuit
- Rice mill circuit
- Fish farming thermostatic control circuit
- Agricultural spraying and insecticide control circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Voltage series negative feedback amplifier circuit
- Power phase sequence display circuit
- Home appliance repair signal generator circuit
